Hello to All,
I found that it's possible to change the action of the button I to put always the text between <i> </i> rather than <em> </em>. Right.
As <em>phase</em> and <i>talic</i> have different functions (or goals) in HTML, I would like to know if it's possible to have two buttons ; one for <i> and one for <em>.
Thanks in advance for your answers.
Regards.
François
Yes, of course. You can
Yes, of course. You can create custom plugins or modify the existing plugin, which is called Basic Styles, to behave a bit differently. You can add this code directly on the page where CKEditor is located.
Hi Seb.
Hi Seb.
Thank you for your answer. I'll try it ASAP.
Regards.
François
