Hi, meanwhile I apologize if the topic was already discussed, but I could not find a solution to this problem: using Asp.net 4.0 framework.
On page I inserted an ajax ModalPopupExtender which contains, inter alia, a control ckeditor.
IE compatibility view Ver.11 and working properly (strangely), but if I open the same page with Mozilla Firefox and Chrome ckeditor control is not working properly, in particular, styles, colors, formatting, fonts, etc.. are not active.
The controls ckeditor outside of Ajax ModalPopup, however, are working properly.
Finally, using the precise debugger respective browser known errors
Edit:
I also tried with jquery modal dialog and unfortunately the result is the same, or do not work the colors, styles, formats, and you can not even write a check in ckeditor
add an image for the use of a
add an image for the use of a ckeditor in jquery modal dialog
any suggestion to solve?
