Greetings.
In http://dev.ckeditor.com/roadmap it says that CKE 4.2 and 4.1.2 are both upcoming in 7 days. Is that so? Are the due dates fixed fixed dates or do they change? I'm doubting the 7 days mark, because it has 13 tickets and 0 of them are closed. When will the next version be released?
Upgrading from 4.1 to 4.1.1 won't be useful if 4.1.2 is coming so soon, but if 4.1.2 only has a single sample change ticket set, will it really be released?
Also, are there any changes made that are not based on trac tickets? Like in github issue tracker or an internal reporting system or something.
4.2 will most likely be
4.2 will most likely be delayed. Maybe a month, easy. 4.1.2 is more optimistic.
Thanks for the update.
Will 4.1.2 be released even though it only has a single ticket set?Edit: Now it has more tickets set. Having accurate milestones is great because it helps me plan if I should upgrade now or wait for 4.1.1 (which we will, some of the marked tickets are important for me), thanks!
On a side note, strikethrough does not work at least when editing posts.
I talked with the team and
I talked with the team and there's a bit of discussion going on about the 4.2 release date. 4.1.2 is on schedule but 4.2 was just delayed by 2 weeks. Remember that milestones represent the code freeze, not release date. After the code is frozen there's about a month of testing before release.
You should post your strikethrough issue on the dev site. You'll have to give as many details as possible.
