Good Evening an error I am experiencing in CKEditor 4.1 is that I have set up templates using the Template module, within the template it contains the following:
<li id="CoreAct" style="padding-bottom:5px;">Core Activities</li>
The list contains 5 seperate items with different ID's that link back to an external stylesheet. However on insert of the template it removes the items ID and Style to leave the source code as:
<li>Core Activities</li>
I have also tried to edit the template once it is on the page using the Source Code function, however once I change the code and switch Source Code off OR save the page the ID and Style disapear once again.
This problem is not only limited to lists in testing is seems to also occur on other attributes such as: <h3>, <th>, <p>.
Are there any fixes to this problem?
Thank you in advance.
I am getting the same issue -
I am getting the same issue - spent about 5 hours trying to figure it out but not managed it yet.
Anyone managed to sort this issue??
It's probably ACF. Add this
It's probably ACF. Add this code to config.js:
Many thanks - I will give
Many thanks - I will give that a go now.
Top man!! That works!!
You have saved me a lot of wime there and I wasted about 3 hours yesterday trying to work that out.
Thanks again!!
Thanks a lot from me too: I
Thanks a lot from me too: I spent like an hour wondering why why the divs I added manually would disappear. First blamed htmLawed, quickly found that the problem was in CKE, but had a hard time figuring out it came from that setting... You saved the day :)
i have same problem in <ul id
i have same problem in <ul id="heading">web desing </ul>
