I was wondering if there is a new function in CKEditor 4 that allows you to add your own rules to the dataProcessor function. I have looked through the documentation but i cannot see a similar function from version 3.
For example in ckeditor 3.x i could use this to change the css widths/heights to actual html widths and heights
var editor = ev.editor,
dataProcessor = editor.dataProcessor,
htmlFilter = dataProcessor && dataProcessor.htmlFilter;
htmlFilter.addRules({
elements :
$ : function( element )
// Output dimensions of images as width and height
if ( element.name == 'img' )
var style = element.attributes.style;
if ( style )
// Get the width from the style.
var match = /(?:^|\s)width\s*:\s*(\d+)px/i.exec( style ),
width = match && match[1];
// Get the height from the style.
match = /(?:^|\s)height\s*:\s*(\d+)px/i.exec( style );
var height = match && match[1];
if ( width )
element.attributes.style = element.attributes.style.replace( /(?:^|\s)width\s*:\s*(\d+)px;?/i , '' );
element.attributes.width = width;
if ( height )
element.attributes.style = element.attributes.style.replace( /(?:^|\s)height\s*:\s*(\d+)px;?/i , '' );
element.attributes.height = height;
return element;
whoops worked it out
i should have used
var htmlFilter = ev.editor.dataProcessor.htmlFilter;
elements :
if ( style )
if ( width )
if ( height )
return element;
thanks
