I am running CKEditor inline on an element that is in another frame.
window.CKEDITOR.inline(otherWindow.getElementById('elem'))
It works.
Are there any pitfalls I might encounter? Anything I can do about them? Will this be a supported feature in the future? Is it likely something will break this feature in later relases?
My main worry is that execCommand will be run on the parent window instead of the element's parent window. Will this be the case?
For reference, my usecase is super simple. I only need the standard formatting features: bold, italic, lists, links and colors, and pasting in plain text only. That's it.
Ben
