i've a problem in my setup of CKEditor.
The location is <removed>.
I've download, extract and test it - but i do not see the replacement of the ckeditor on the textarea.
Test it on FF28 and Opera12.01. In IE 6 i see the normal textarea.
The consol in FF throw any informations an two errors.
ReferenceError: $ is not defined ckeditor.js:929 SyntaxError: Using //@ to indicate sourceMappingURL pragmas is deprecated. Use //# instead jquery.min.js:1 ... ... GET http://<removed> [HTTP/1.1 404 Not Found 16ms]
By testing with Firebug, the script location of ckeditor.js was found.
What is my fault?
Regards raiserle
No idea. The page you linked
No idea. The page you linked does not work.
Sorry, my server was offline.
You're using some 3rd party
You're using some 3rd party plugin which uses local storage (autosave?). I guess that you have to attach jQuery before CKEditor, because that plugin uses it. Or its other requirement, but anyway, you should find it in this plugin's documentation.
Ok, thanks.
Ok, thanks.
That comes not clearly from this documenation http://docs.ckeditor.com/#!/guide/dev_installation.
You mean: The exmple works with Basic download. But: There is no words about this, in your documentation.
regards
AutoSave is not an official
AutoSave is not an official CKEditor plugin. It was implemented and is maintained by someone else, so that developer has to provide documentation. We cannot do that. And CKEditor does not need jQuery to work, so everything is ok with the documentation.
I mean, you can write the
I mean, you can write the documentation understandable. You are provide the package-selector with some plugins.
You wrote in your documentation... "For a production site we recommend you choose the default Standard Package and click the Download.." In the picture: "Select and download a CKEditor package".
There is no HINT about other plugins ... use jQuery or somthings. Or any words about: Use PLUGINS, then read the Plugin-documentation.
regards
Thank you for you feedback. I
Thank you for you feedback. I forwarded it to our Documentation Manager and we'll check if hint about additional requirements and plugins documentation may be added at some point of the general documentation.
Very quick support, nice, Thanks!
Thanks reinmar,
your hint of "requirements" e.g. jquery was the solution.
And the CKEditor are the best!
Regards raiserle
[closed]
