- Status changed from new to closed
- Resolution set to invalid
This is core functionality of editor and can't be turned off. In fact every editor works that way.
Editor works with clean HTML. If user enters invalid (e.g. p inside span) HTML editor has to correct it according to specification. If this didn't happen editor would become very unstable application with many unpredicted styling errors which we can't allow.
comment:2Changed 103 seconds ago by samsam8899
this core funcitonality is wrong. I don't meant there shouldn't be an auto fix function, the problem is it never functioned properly. While other html editors also perform auto correction, but they didn't mess up the correct html tags. You got to believe this function is faulty and better be humbled yourself and make a big coding review'''
It's clearly impossible to
It's clearly impossible to state if there's a bug in CKEditor or not because you haven't provided any info.
You call it "FCKeditor", but that name was changed years ago, and anyway, you don't state which version you're using.
You don't show what's the original HTML and the way that CKEditor modifies it.
And if you thought that CKEditor is already modifying too much your code, wait for 4.1, you'll have a heart attack :-)
