I have 2 editor in one page. I am using the latest version. I upload one image in one editor which is a base64image plugin. On another editor I set another image to upload, but after I click the ok button it put the same image which was insert in the first editor. FYI, I have to use multiple editor in one page with base64image. What to do to avoid this issue?
Wed, 06/11/2014 - 22:08
CKEditor doesn't have a
CKEditor doesn't have a base64 image plugin, so you're using a 3rd party plugin. It would help to know:
1. Do you upload the images in both editors using the same plugin? If not, what's the other plugin?
2. Do these images have same name?
3. Could you provide screen cast or screen shots showing this issue?
2 editor base64image plugin inserting problem
1. Yes I am using same plugin for both editor.
2. No both are different file.
3. Please attached. Also I will post another image as only 3 image can be added in the post.
base64 Image
Please see attached image which I am using for image upload.
Ok, then you will have let
Ok, then you will have let the plugin's creator know about this issue. Base64 Image is a 3rd party plugin so we can't help you there. You can leave a comment on the plugin's page.
