I am using the jQuery adapter to integrate Ckeditor with the new version of Digitalus Framework, and running into an odd issue. The content forms load via ajax, using jQuery.
When you first load the CMS it loads the ckeditor files. Then when you edit a page the editor does not seem to bind to the control properly the first time. The editor loads and functions perfectly, but when you save the page (which posts with the jquery form plugin) the contents of the control are not updated. I have confirmed that it is posting the old data with Firebug. Once this has been done one time every other form functions perfectly, posting and updating properly.
Any ideas on where to look for this issue?
Re: using ckeditor in a form which loads via ajax
Then you can recover the value of textarea in JavaScript.
Thanks!!
