Hello I'm trying the ckeditor for my first time, I have created a new web proyect and followed the installation steeps.
My problem is that my default.aspx don't show the toolbar I have the ckeditor control and I can write in it.
In the property tab I have:
toolbar--> full and the rest of setting is by default.
Re: toolbar is not showed
viewtopic.php?f=11&t=24223
now is working fine
thanks
Right-click ANY toolbar and hit the Customize option way at the bottom. Make sure you're on the Tool bars tab of that dialog box. Select (but do NOT unchecked) the Standard toolbar and hit Reset. Confirm that you want to reset it. You should have your File menu back
