I've been scouring the boards for a couple of hours and while there is a lot of debate about whether or not the editor is supported on the various flavors of ios and android, I would just like to disable it. Is that a configuration option within ckeditor or something I have to code on my end, if the latter any best practices would be helpful
Regards
Regards
Re: Is there a simple way to disable CKEditor on mobile phon
ckeditor certainly works fine on Ipad iOS5.
