I have a simple question: how I could insert trought HTML a selection field in CKEditor and avoid the editor to manage the field?
Example: I insert the code in the source code view
<select name="selection test" onChange="alert('test');"><option value="1">1</option><option value="2">2</option></select>
and when I came back to the WYSIWYG view I would to use the field so when I select a value the javascript alert me.
Is it possible?
Is it possible?
Re: selection field problem
I add a selection field using the source code editor, and I couldn't use it. When the mouse hover over it the ckeditor answer with the move oprion and if I click on it the ckeditor give me the possibility to resize the field (as showed in the attached image 1).
I want that the ckeditor don't manage the selection field, I want it as a normal selection field (as showed in attached image 2).
I try the removePlugins : contextmenu,forms,resize' option, but it doesn't work. It remove only the button "Selection Field".
