I have a simple application which creates a ckeditor instance with scayt autostartup configured to true. IE breaks when I reset the instance using setData. After searching for similar issues, I found that some folks have determined that the instance should be destroyed and replaced. When I do that, again configuring scayt autostartup to true, IE and Firefox give different errors, probably occurring from the same root problem, which indicate that the scayt widget is already activated. This goes away when I start it up with scayt autostartup configured to false (actually, simply omitted).
Short of simply not ever configuring it to true, any ideas on how to make scayt start up on the second instance? It does work, as shown below, in all browsers if I delete the scayt autostartup parameter.
Here are relevant code snippets:
Initial setup
Dialog box triggered by click on a "Cancel Changes" button (changes since last save):
ClearChanges function:
Initial setup
var config =
toolbar : [...],
scayt_autoStartup : true
$(".CKEditorRichTextEditor").each(function()
CKEDITOR.replace($(this).attr("id"), config);
CKEDITOR.instances[$(this).attr("id")].on("instanceReady", function(e)
e.editor.dataProcessor.writer.indentationChars = "";
e.editor.dataProcessor.writer.lineBreakChars = "";
$("#GenericDialogBox").dialog(
title: "Cancel Changes to Your " + ChangeTargetName,
modal: true,
buttons:
Yes: function()
ClearChanges(SelectedFormElementsSet);
$(this).dialog("close");
No: function()
function ClearChanges(SelectedFormElementsSet)
// Added this to fix IE break (caused below as commented)
CKEDITOR.instances[$(".CKEditorRichTextEditor", SelectedFormElementsSet).attr("id")].destroy(true);
CKEDITOR.replace($(".CKEditorRichTextEditor", SelectedFormElementsSet).attr("id"), config);
CKEDITOR.instances[$(".CKEditorRichTextEditor", SelectedFormElementsSet).attr("id")].on("instanceReady", function(e)
// This is the code that originally caused IE to break
CKEDITOR.instances[$(".CKEditorRichTextEditor", SelectedFormElementsSet).attr("id")].setData($(".AssessmentEntrySection", SelectedFormElementsSet).data("InitialTextValue"));
Re: scayt autostartup after destroy and replace doesn't work
http://dev.ckeditor.com/ticket/9439
