Hello All,
i have a web application i wrote that is using a basic WYSIWYG editor. i try to implement ckeditor and have the following problem:
my application is fully ajax, that's mean that every page request is done via ajax and then parsed. iv'e tried the ckeditor for php example (that was running ok when not in ajax mode) but of course it's not running under the ajax since the php code is parsed to <script... > tags that ajax can not read in any way.
is there any method that may work for this situation?
btw, i read the examples for ajax with the create and remove buttons but that won't help me in this case since only when loading the ajax page i know what and how many wysiwyg frames to load
Re: running ckeditor from an ajax application
See the trivial example
1.html
// include jQuery <script src="js/jquery-1.4.2.min.js"></script> <script> $(function() { // load 2.html into div #my $("#my").load("2.html") }); </script> <div id="my"></div>2.html
<script> alert("hello!") </script>When you open 1.html, it executes AJAX call to the 2.html. As you will see the script from 2.html is normally executed (just as in case of a normal, non-AJAX request) and the alert is shown.
Please post more details on your problem.
<script type="text/javascript"> function reloadPage(pageName,formName,refreshElem) { xmlHttp=GetXmlHttpObject(); xmlHttp.onreadystatechange=stateChanged; function stateChanged() { if (xmlHttp.readyState==4) { document.getElementById(refreshElem).innerHTML=xmlHttp.responseText; undimm(); } } var url=''; if (formName) { var x=document.getElementById(formName); for (var i=0;i<x.length;i++) { x.elements[i].value = x.elements[i].value.replace(/&/g,"%26"); url += x.elements[i].name+'='+x.elements[i].value+'&'; } } if (url) changeFieldValue('txt',url); xmlHttp.open("POST",encodeURI(pageName),true); xmlHttp.setRequestHeader('Content-Type','application/x-www-form-urlencoded;charset=UTF-8'); xmlHttp.send(url); }Re: running ckeditor from an ajax application
http://brightbyte.de/page/Loading_script_tags_via_AJAXrunScript
Thanks!!
about jquery - i have my suggestions about loading this amount of code for nothing but i do my best.
iv'e tried the solutions that you have posted and it seems to be better, but now i get this error:
ReferenceError: Can't find variable: CKEDITOR
this is probably because the script in the code does not like the <script type="text/javascript" src="/ezadmin3/ckeditor/ckeditor.js?t=B37D54V"></script> and can't parse it.
is there any way to install this code before calling the ajax?
http://paulirish.com/2009/caching-and-g ... aries-api/
