Dear Sir, and Madam,
I've done a function that will replace all abbr by their expressions, actually this code works fine.
All abbr and their correspondance are recorded on my database.
Here is my code:
So Actualy this code works fine. But I would like to make it works onkeyup.
Is there a way I can do that?
Anykind of help will be much appreciated.
Receive all my utmost Respect.
Kind Regards.
SP.
Here is my code:
editor = CKEDITOR.instances.suivi; //fck is just my instance name you will need to replace that with yours
<?php $rqt="SELECT * FROM `glossaire` WHERE `id_company` ='".$societe['id']."'";
$result=mysql_query($rqt);
while($data=mysql_fetch_assoc($result))
var edata = editor.getData();
var replaced_text = edata.replace("<?php echo ($data['libelle']) ; ?>", "<?php echo ($data['texte']) ; ?>"); // you could also use a regex in the replace
editor.setData(replaced_text);
<?php } ?>
Kind Regards.
SP.
