I'm using CKEditor 3.0.1
I find it very annoying that radio controls are always shown inside a hbox. It would be very useful to be able to list radio controls vertically.
If you look at the "radio" function definition in "_source/plugins/dialogui/plugin.js", you will fine at line 421:
If you look at the "labeledElement" function definition in the same file, there seems to be such a distinction possible:
Maybe the same could be done for listing radio controls. Or maybe I'm missing something and there IS a way? My goal is to find a way without modifying the CKEditor source code so that it can easily be updated with future releases.
- Chris
new CKEDITOR.ui.dialog.hbox( dialog, [], inputHtmlList, html );
if ( elementDefinition.labelLayout != 'horizontal' )
else
}Maybe the same could be done for listing radio controls. Or maybe I'm missing something and there IS a way? My goal is to find a way without modifying the CKEditor source code so that it can easily be updated with future releases.
- Chris
Re: radio items always inside hbox
Of course, you should double check first that your ideas are right and the patch is really needed.
to
Then add labelLayout to the radiobutton:
{ type : 'radio', id : 'xxx', label : 'XXX:', labelLayout: 'vertical', items : [ [ 'xxx', 'X' ], [ 'yyy', 'Y' ], [ 'zzz', 'Z' ] ] , 'default' : 'X' }The only problem is that you have to use:
<script type="text/javascript" src="ckeditor_source.js"></script>
And if you ever update ckeditor to a newer version - check if the code is there (or a similar solution) - and if not add it again...
