hey folks
i have an old application based on ASPmaker, which had FCKeditor built in. its basically a small Classic ASP system.
i changed the editor to CKeditor, newest version a few weeks ago,
the toolbars display properly.
but now, when the server-side code tries to read the textarea field -it doesnt seem to have access to anything, and it becomes empty.
the form, has an upload file input field, thus the systems uses a BLOBl reader to access the form fields.
i have put together a small demo, and can also paste some code.
again - the same code works perfectly with FCkeditor.
code follows below.
much appreciated in advance!
this is the HTML code:
this is the ASP function that reads the the fields and is supposed to response the values:
code follows below.
<form name="fNewsadd" id="fNewsadd" action="?cat=<%=x_cat_ID%>" method="post" enctype="multipart/form-data"> <input type="hidden" name="a_add" value="A"> <input type="hidden" name="EW_Max_File_Size" value="2000000"> <% If Session(ewSessionMessage) <> "" Then %> <p><span class="ewmsg"><%= Session(ewSessionMessage) %></span></p> <% Session(ewSessionMessage) = "" ' Clear message End If %> <table border="0" cellspacing="1" cellpadding="4" bgcolor="#CCCCCC"> <tr> <td class="ewTableHeader"><span>Title<span class='ewmsg'> *</span></span></td> <td class="ewTableAltRow"><span id="cb_x_title"> <input type="text" name="x_title" id="x_title" maxlength="255" size="70" value="<%= Server.HTMLEncode(x_title&"") %>"> </span></td> </tr> <tr> <td class="ewTableHeader"><span>Content</span></td> <td class="ewTableAltRow"><span id="cb_x_content"> <textarea cols="35" rows="4" id="x_content" name="x_content" class="editor"><%= x_content %></textarea> </span></td> </tr> <tr> <td class="ewTableHeader"><span>Upload Image</span></td> <td class="ewTableAltRow"><span id="cb_x_img"> <input type="hidden" name="a_x_img" value="3" /> <input type="file" id="x_img" name="x_img" size="30" /> <strong>Note</strong>: Image MUST be 443 pixels wide, by 296 high. </span></td> </tr> </table> <p> <input type="hidden" name="x_viewed" id="x_viewed" size="30" value="0"> <input type="button" name="btnAction" id="btnAction" value="ADD" onClick="EW_submitForm(this.form);"> </form>
'call the function:
RequestBlobData()
Function RequestBlobData()
Dim rawData, separator, lenSeparator, dict
Dim currentPos, inStrByte, tempValue, mValue, value
Dim intDict, begPos, endPos
Dim nameN, isValid, nameValue, midValue
Dim rawStream
If Request.TotalBytes > 0 Then
Set rawStream = Server.CreateObject("ADODB.Stream")
rawStream.Type = 1 'adTypeBinary
rawStream.Mode = 3 'adModeReadWrite
rawStream.Open
rawStream.Write Request.BinaryRead(Request.TotalBytes)
rawStream.Position = 0
rawData = rawStream.Read
separator = MidB(rawData, 1, InStrB(1, rawData, ChrB(13)) - 1)
lenSeparator = LenB(separator)
Set dict = Server.CreateObject("Scripting.Dictionary")
currentPos = 1
inStrByte = 1
tempValue = ""
While inStrByte > 0
inStrByte = InStrB(currentPos, rawData, separator)
mValue = inStrByte - currentPos
If mValue > 1 Then
value = MidB(rawData, currentPos, mValue)
Set intDict = Server.CreateObject("Scripting.Dictionary")
begPos = 1 + InStrB(1, value, ChrB(34))
endPos = InStrB(begPos + 1, value, ChrB(34))
nameN = MidB(value, begPos, endPos - begPos)
isValid = True
If InStrB(1, value, stringToByte("Content-Type")) > 1 Then
begPos = 1 + InStrB(endPos + 1, value, ChrB(34))
If endPos > 0 Then
intDict.Add "FileName", ConvertToText(rawStream, currentPos + begPos - 2, endPos - begPos, MidB(value, begPos, endPos - begPos))
begPos = 14 + InStrB(endPos + 1, value, StringToByte("Content-Type:"))
endPos = InStrB(begPos, value, ChrB(13))
intDict.Add "ContentType", ConvertToText(rawStream, currentPos + begPos - 2, endPos - begPos, MidB(value, begPos, endPos - begPos))
begPos = endPos + 4
endPos = LenB(value)
nameValue = MidB(value, begPos, ((endPos - begPos) - 1))
Else
endPos = begPos + 1
isValid = False
End If
Else
nameValue = ConvertToText(rawStream, currentPos + endPos + 3, mValue - endPos - 4, MidB(value, endPos + 5))
End If
If isValid = True Then
If dict.Exists(byteToString(nameN)) Then
Set intDict = dict.Item(byteToString(nameN))
If Right(intDict.Item("Value"), 2) = vbCrLf Then
intDict.Item("Value") = Left(intDict.Item("Value"), Len(intDict.Item("Value"))-2)
End If
intDict.Item("Value") = intDict.Item("Value") & ", " & nameValue
Else
intDict.Add "Value", nameValue
intDict.Add "Name", nameN
dict.Add byteToString(nameN), intDict
End If
End If
End If
currentPos = lenSeparator + inStrByte
Wend
rawStream.Close
Set rawStream = Nothing
' Get action
sAction = getValue(dict, "a_add")
EW_Max_File_Size = getValue(dict, "EW_Max_File_Size")
x_newsID = getValue(dict, "x_newsID")
x_title = getValue(dict, "x_title")
x_content = getValue(dict, "x_content")
' Check the file size
If fs_x_img > 0 And CLng(EW_Max_File_Size) > 0 Then
If fs_x_img > CLng(EW_Max_File_Size) Then
Response.Write Replace("Max. file size (%s bytes) exceeded.", "%s", EW_Max_File_Size)
Response.End
End If
End If
fn_x_img = getFileName(dict, "x_img")
' Check the file type
If Not ewUploadAllowedFileExt(fn_x_img) Then
Response.Write "File type is not allowed."
Response.End
End If
ct_x_img = getFileContentType(dict, "x_img")
x_img = getFileData(dict, "x_img")
Call ewGetImageDimension(x_img, wd_x_img, ht_x_img)
If wd_x_img < 0 Or ht_x_img < 0 Then
wd_x_img = getValue(dict, "wd_x_img")
ht_x_img = getValue(dict, "ht_x_img")
End If
a_x_img = getValue(dict, "a_x_img")
If IsObject(intDict) Then
intDict.RemoveAll
Set intDict = Nothing
End If
dict.RemoveAll
Set dict = Nothing
RequestBlobData = True
response.Write("x_content = " & x_content)
response.Write("<br>x_title = " & x_title)
Else
RequestBlobData = False
End If
End Function
Re: problem, when upgrading from FCKeditor
once i disabled it, it work.
i will send you the link in a PM, maybe you will be able to see what the issue with the function is
thanks again!
I've never understood why browsers behave that way. It would be much saner if the onSubmit listener of a form was always called, no matter if it's being submitted for one reason or for another.
