Hi
I am having some problems when using setData in Internet Explorer. When using it I get the following error 'this.$.innerHTML' is null or not an object'.
This only happens when I use setData in a custom save function I made
I use setData elsewhere on the same page and having no problems with it.
Also this works fine in Firefox.
Does anyone have an idea to what the problem might be?
CKEDITOR.plugins.registered['save'] = {
init: function (editor) {
var command = editor.addCommand('save',
modes: {wysiwyg: 1, source: 1},
exec: function (editor) {
var data = editor.getData();
var elem = $('storeArea');
elem.update(data);
editor.setData('');
editor.ui.addButton('Save', {label: 'Gem', command: 'save'});
Re: problem with setData in Internet Explorer
