Today I downloaded CKeditor for Joomla 1.6 v1.6 RC4 and tried to translate it into Chinese language.
Then I noticed that in the XML file (/administrator/components/com_ckeditor/config.xml), there are something wrong:
Following options has space characters included:
Left to right
Right to left
P Elements
BR Elements
Div Elements
So they can't be translated. You should use underscore instead of spaces.
And, you also used Yes and No directly for options, which can not be translated. Because Joomla 1.6 has a global definition for Yes and No, you should use:
JYes
JNo
Hope you will fix these soon.
Thanks.
Left to right
Right to left
P Elements
BR Elements
Div Elements
JYes
JNo
Thanks.
Re: language issue about CKeditor for Joomla! 1.6
thx for notice this.
I will fix this and add to next release.
EDIT:
It's fixed and waiting for next release.
