//CLEANING THE INSTANCE WHEN WITH AJAX I SET AGAIN MY DIV
if(CKEDITOR.instances["m_sTesto"] != undefined)
CKEDITOR.remove(CKEDITOR.instances['m_sTesto']);
//FIRST TIME I LOAD THE PAGE => SO I SET MY NEW EDITOR WITH MY CONFIG
if( !editorCK)
var editorCK = CKEDITOR.replace( 'm_sTesto');
//FROM THE SECOND TIME => I SET NEW EDITOR WITH MY OLD CONFIG AND I ADD MY OLD BUTTON
else
hInternalLinkButton = editorCK.ui._.items.internalLinkButton;
//CKEDITOR.replace( 'm_sTesto', editorCK.config);
editorCK = CKEDITOR.replace( 'm_sTesto', editorCK.config);
editorCK.ui.addButton( 'internalLinkButton', hInternalLinkButton);
// Listen for the "pluginsLoaded" event, so we are sure that the
// "dialog" plugin has been loaded and we are able to do our
// customizations.
editorCK.on( 'pluginsLoaded', function( ev ){
// If our custom dialog has not been registered, do that now.
if ( !CKEDITOR.dialog.exists( 'internalLinkPanel' ) ) {
// We need to do the following trick to find out the dialog
// definition file URL path. In the real world, you would simply
// point to an absolute path directly, like "/mydir/mydialog.js".
//var href = document.location.href.split( '/' );
//href.pop();
//href.push( 'api_dialog', 'my_dialog.js' );
//href = href.join( '/' );
// Finally, register the dialog.
CKEDITOR.dialog.add( 'internalLinkPanel', '../internalLinkPanel.js' );
// Register the command used to open the dialog.
editorCK.addCommand( 'internalLinkPanelCmd', new CKEDITOR.dialogCommand( 'internalLinkPanel' ) );
// ADDING MY NEW BUTTON
label: 'Collegamenti interni',
command: 'internalLinkPanelCmd',
//icon: 'http://gacela.labf.usb.ve/GacelaWiki/attach/Pic/playboy.png'
icon: '/manager/_editor/ckeditor_core/images/download.gif'
// Define changes to default configuration here. For example:
config.language = 'en';
// config.uiColor = '#AADC6E';
//Gestione del pulsante 'Cerca sul server'
config.filebrowserBrowseUrl = "/da_sviluppo/index.php?bLink='editor html'";
//config.filebrowserUploadUrl = '/da_sviluppo/index.php';
//config.filebrowserImageBrowseUrl = '/da_sviluppo/index.php';
config.filebrowserFlashBrowseUrl = '/ckfinder/ckfinder.html?Type=Flash',
config.filebrowserUploadUrl = '/ckfinder/core/connector/php/connector.php?command=QuickUpload&type=Files',
config.filebrowserImageUploadUrl = '/ckfinder/core/connector/php/connector.php?command=QuickUpload&type=Images',
config.filebrowserFlashUploadUrl = '/ckfinder/core/connector/php/connector.php?command=QuickUpload&type=Flash'
config.toolbar = [
['Source','-','Templates'],['TextColor','BGColor'],['Maximize', 'ShowBlocks'],
['Cut','Copy','Paste','PasteText','PasteFromWord','-','Print', 'Scayt'],
['Undo','Redo','-','Find','Replace','-','SelectAll','RemoveFormat'],
['Bold','Italic','Underline','Strike','-','Subscript','Superscript'],
['NumberedList','BulletedList','-','Outdent','Indent','Blockquote'],
['JustifyLeft','JustifyCenter','JustifyRight','JustifyBlock'],
['Link','Anchor','internalLinkButton','Unlink'],
['Image','Table','HorizontalRule','SpecialChar','PageBreak']
Re: how to reload old editor (again and again) with ajax calls?
any suggestions?
nothing?
i trust you
