Setup your config:
At server-side to send back the selected file url (aka .setUrl() ):
config.filebrowserImageBrowseUrl = yourBrowserURL; config.filebrowserImageUploadUrl= yourBrowserURL;
var CKEditorFuncNum = window.location.href.replace(/.*CKEditorFuncNum=(\d+).*/,"$1")||alert('Error: lost CKEditorFuncNum param from url'+window.location.href)||1;
window.opener.CKEDITOR.tools.callFunction(CKEditorFuncNum, selectedFileUrl);
Re: help to Filebrowser server-side implementation
In fckeditor 2.x I had an plugin: Ajax File Manager. I tried
the config lines posted and that worked great.
But the retur I didn't get to work.
Previously i had this simple code:
window.opener.SetUrl( url ) ;
window.close() ;
So I tried to paste in the lines from the post but it only returned javascript errors.
Second question. What is the config lines for flash browser button, link browser button and so on. Why is not this information in the setup document.?
I use Ajax File Manager and try this
function selectFile() { var selectedFileRowNum = $('#selectedFileRowNum').val(); if(selectedFileRowNum != '' && $('#row' + selectedFileRowNum)) { // insert information now var url = $('#fileUrl'+selectedFileRowNum).val(); var CKEditorFuncNum = window.location.href.replace(/.*CKEditorFuncNum=(\d+).*/,"$1")||alert('Error: lost CKEditorFuncNum param from url'+window.location.href)||1; alert(CKEditorFuncNum); window.opener.CKEDITOR.tools.callFunction(CKEditorFuncNum, url); window.close() ; }else { alert(noFileSelected); } }but it returns empty value. help please
