Hi!
I've another problem...
I've put CKEDITOR in a central frame...
and into my specific template I do this
and then I add a button like in the sdk example
and taht works fine...
but sometimes I reload the CKEDITO frame, and I got an error (The instance already exists )
the first solution was add something like this
and it works fine.... the only problem is that my custom button is not recreated into my ckeditor istance...
can you help me???
thanks!!!!!!!!
var editorCK = CKEDITOR.replace( 'm_sText', ... )
editorCK.on( 'pluginsLoaded', function( ev ) {
if ( !CKEDITOR.dialog.exists( 'internalLinkPanel' ) ) {
CKEDITOR.dialog.add( 'internalLinkPanel', '../internalLinkPanel.js' );
editorCK.addCommand( 'internalLinkPanelCmd', new CKEDITOR.dialogCommand( 'internalLinkPanel' ) );
editorCK.ui.addButton( 'internalLinkButton',
label : 'Collegamenti interni',
command : 'internalLinkPanelCmd'
if (CKEDITOR.instances["sText'"] != undefined) {
CKEDITOR.remove(CKEDITOR.instances[sText']);
can you help me???
thanks!!!!!!!!
Re: custom button is not reloaded after CKEDITOR is rebuild
http://www.kindblad.com/2008/09/07/fckeditor-2x-how-to-add-a-new-button-with-custom-javascript-to-the-toolbar/
