Dear ckeditor v3 users,
I have got a problem when using "contentEditable" as follows:
If I put this code (see below) into an editor instance (source view)
and switch back to wysiwyg view
I can click on the string "variable" and move it with the mouse.
But I cannot - this is what I wanted - change the string "variable" when I use Internet Explorer.
In Firefox 3+ the "contentEditable=false" does not work.
Is there a workaround here?
Please advice.
Code example here:
Best regards
toller43
Please advice.
Code example here:
<textarea id="editor" name="editor">
normal Text
<span style="background-color:#FFFE00; color:#FF0FFF;" contentEditable="false"
>variable</span>
End
</textarea>
var eddy =CKEDITOR.replace('editor', {
height : 250 ,
width : 300
Best regards
toller43
Re: contentEditable: IE ok, FF Problem
perhaps this can clarify what I need:
Within the textarea, replaced by ckeditor, I want to have single words that
cannot be changed by the user.
My text could look like this:
normal text this text is not editable ...
How can I manage this within the ckeditor textarea?
It works fine when I use IE, but does not work in Firefox 3.
Any ideas??
Best regards
toller43
Thanks!
And when the 3.3 will come ?
thks
Sorry for my english :s
Look at the SVN to get all the current info.
"When it's ready"
I now use version 3.4.1 of ckeditor, but the problem still remains the same as before.
Firefox 3.6.10 kills "contenteditable" attribute when moving the text, whereas IE
works fine.
I have prepared a document (see attachment) that shows screenshot for both, IE and firefox,
and the results.
The text "I_am_contenteditable" should be yellow, but I cannot upload a pdf, so I made a tif of it.
[b]As a summary: It works in IE 8 (compatibilty mode 7), but not in firefox 3.6.x.[/b]
So again my question, what can I do???
Best regards
toller43
