config.baseHref = 'file://C:/Test/';
Setting baseHref to a local path is not working when using the image dialog. Do I miss something?
Re: config.baseHref problem
I guess that jqwysiwg might let you do it because I don't think it uses an IFRAME but without looking at the code, I'm unsure. jqwysiwg also doesn't have half the features of CKEditor either, it would require a lot of work to even get jqwysiwyg anything like close to some of CKEditor's most basic out of the box features.
It's unfortunate but I don't think there is anything that can be done. The IFRAME editing area is a core part of CKEditor.
Zanpakutō
Sorry, I thought that you were talking about a normal web page.
In any case, the important part is that browsers (in your case IE) restrict the access to local resources, and it depends on the origin of the main document and the configuration of the "security zones".
You should start using a plain html page that has that base href set and add some images like you want to verify if that works.
You can also try to use paths relative to the main document, the problem is that it will be quite harder to debug any problem because you can't check for 404 errors
