Is there support for a "click" event for editor instances? At the moment I'm struggling with an issue under IE8 where to get focus on an editor instance the user has to click right in the top of the editor. Under FF you can click anywhere inside the editor. I was going to listen for the "click" event and give it focus (something similar to which I assume is happening internally) but I can't see that it's supported.
Any help?
Thanks.
Any help?
Thanks.
Re: "click" event for editor instances?
contents.css
html,body{height:100%;}
