I use ckeditor(version 3.5) in a news website(asp.net),but I have a problem.
I will read the news content from table and show it in ckeditor for user to edit,but ckeditor can not show anything.
the code is :
var record =
(from lQuery in dc.iicNews
select lQuery).First();
this.txtTitle.Text = record.title;
//show news content in ckeditor
string strScript = "<script type='text/javascript'>editor.setData('" + record.content + "');</script>";
ClientScript.RegisterStartupScript(this.GetType(), "editorKey", strScript);
ckeditor will show nothing.
but the code
string strScript = "<script type='text/javascript'>editor.setData('" + record.title + "');</script>";
can show the news title correctly.
field "title" is nchar(255) and field "content" is nText in sql database.
the code is :
var record =
but the code
Re: ckeditor can not work correctly with linq
I guess that if you use the asp.net control available here you won't have this problem as it should already take care of these issues.
It's a textarea in my code,and there is a runtime error when I add "runat=server".
I used server control of asp:TextBox
and set the clientidmode "static" then ckeditor work correctly
