I have a CKEditor inside a xHTML-page. When I look in the source-view via CKEditor everything is compliant (e.g. break is <br/>). But when I look at the source via Firebug (or submit the form) the <br/> becomes <br>. Same is with the <img>-Tag.
Are there any hints on this? I tested already some thing (e.g. make the page xHTML) but nothing did work out so far.
Thanks for any help in advance!
Regards,
Flo
Regards,
Flo
Re: <br> and <img> Tags not XHTML-like
This wasn't a problem of CKEditor. I did use jQuery's html-method that relies on the DOM innerHTML property to get CKEditors contents (to do some filtering). This property seems to be unable to handle XHTML at all (tested in FF and Chrome).
You need to replace all slashes manually.
