SOLVED - I figured it out. Turns out it was a ColdFusion issue, not CKEditor. Anyone else experiencing this problem can solve it by opening the application.cfm file in the root of your directory and adding: scriptprotect="none" inside the cfapplication tag.
I've just started using CKEditor in a really simple ColdFusion/Access CMS I built, and I'm wondering if I'm missing something really easy here. I go to embed a YouTube through the CKEditor... and in the flash preview it shows the correct info and preview image... then I click ok and I get a red box that says "FLASH" in the middle. I just figured thats the way it works. But when I update the page, it changes the <object> tag to <invalid tag> and the video doesn't show... is there a block tag list or something I should edit to turn it on something?
Thanks so much for the help in advance...
Re: YouTube Embed Issue? - SOLVED (ANSWER INSIDE)
Yeah.. me too this problem
This is link
http://cksource.com/forums/viewtopic.php?f=11&t=15751
Thank's
Marco
"....hen I click ok and I get a red box that says "FLASH" in the middle..." but dont work, why ???
Thank you again
Marco
