Looks like some mangled CSS... Which CKEditor version, skin, OS & browser do you use? What's your configuration, have you done any customizations with regards to dialog window sizes, styles etc?
Can you reproduce the problems on the CKEditor samples that are available in the "_samples" folder of your CKEditor installation?
If not, use Firebug to see which CSS rules apply to the distorted elements and compare them to the properly working samples.
Re: Whats the Problem??
