Hi!
It would be great if it was possible to define the editor to either:
a) Use standard HTML syntax *
b) Use XHTML syntax *
c) Conform to a custom DTD
d) Conform to a custom XSchema
* = Make it possible to validate source according to the standards, but also to allow to extend it with other elements if needed.
/JohnF
/JohnF
Re: Using schema for syntax
