Is it possible to use block element H1 as inline element (as span for example) in CKEditor?
I have tried to do like this, but it does't work:
CKEDITOR.on('instanceReady',
function(ev)
// transform block element to inline
ev.sender.dtd['p']['h1'] = 1
ev.sender.dtd.$block['h1'] = 0;
ev.sender.dtd.$inline['h1'] = 1;
ev.sender.dtd.$body['h1'] = 0;
var dtd = CKEDITOR.dtd;
dtd['p']['h1'] = 1
Re: Using block element as inline
If you want to do this you should modify CKEDITOR.DTD object before initializing editor, not on instanceReady (which is fired after that). Also - don't reset values by assigning "0" - just use delete, so "x in DTD" won't be broken. And the last thing - changing DTD may still not be enough, because in some place we're checking also elements styles, to check whether it's inline or block.
Anyway - you're trying to do something very unusual and much probably wasting your time ;).
