Hi
I have a custom-built CMS that generally requires editor input to retain the line break after a closing paragraph, such as a normal page. However, I have a js News system that requires no line break after a paragraph (ie <p>blah</p><p>blah...</p>). I know I can do this with the breakAfterClose (set to false) parameter. So, I want my News system to call a different version of the ckeditor.js file.
I have a renamed version of the ckeditor.js file and understand from the documentation that I have to declare this version when it's needed but I'm having problems. Maybe I've missunderstood, I've been using this:
var CKEDITOR_BASEPATH = '/mycms/ckeditor/';
<script src="ckeditor_myversion.js" type="text/javascript"></script>
<textarea name="news"></textarea>
CKEDITOR.replace( 'news',
customConfig : '/mycms/ckeditor/mycustomfile/ckeditor_config.js'
The editor doesn't appear. Am I being stupid or is there something I've missed? Any help would be greatly appreciated.
Just fwiw, I found that by changing only the htmlwriter plugin to contain 'breakAfterClose:false' didn't work on it's own, where as the ckeditor.js change does work.
M
M
