Hi, when I set up my editor I'm using a replace all so that I simply set the class of the textarea for it to change, However I want to setup my CKFinder for the Browse Server button, the SetupCKEditor function requires the instance of the editor to set it up it appears, is there any way of doing this with a ReplaceAll??? Thanks
Mon, 09/07/2009 - 14:52
Re: Using SetupCKEditor with ReplaceAll
CKFinder.SetupAllCKEditor = function( basePath, imageType, flashType ) { // Setup current instances for (var editorName in CKEDITOR.instances) CKFinder.SetupCKEditor(CKEDITOR.instances[editorName], basePath, imageType, flashType) ; // Future instances CKEDITOR.on('instanceCreated', function(e) { CKFinder.SetupCKEditor(e.editor, basePath, imageType, flashType) ; }); }Example:
CKFinder.SetupAllCKEditor("/controls/ckfinder/");Re: Using SetupCKEditor with ReplaceAll
