I have some textareas on my page and they're all using the default 'class="ckeditor"' selector to get themselves replaced by CKEditor and I was wondering if there was a way to have it use the Basic toolbar for all of them?
I can't edit the config.js file, because other instances of the default replacement (on other pages) may want to use the Full toolbar. I was just wondering if there was a code snippit I could run to make it use the Basic toolbar as default for this particular page, be it by including another config file after I include the ckeditor.js file (I've actually already tried this, and it didn't work), or something similar?
I can get it to work by calling the replace method manually for each one, but I'd rather just include a script that does it automatically for all the textareas on the page in which it's run.
I hope that all made sense.
Any ideas?
Any ideas?
Re: Use basic toolbar with default selector
Something like:
Double check the config api, I didn't look it up. But something like that will work.
Put that somewhere where it will execute first.
I included the ckeditor.js file, and right after that, included a file that had that line in it, and it did not work.
CKEDITOR.editorConfig = function( config ) { config.toolbar = "basic"; };Or, to preserve the original contents of config.js, monkey patch it:
var oldConf = CKEDITOR.editorConfig; CKEDITOR.editorConfig = function( config ) { oldConf(); config.toolbar = "basic"; };Re: Use basic toolbar with default selector
