Reproduced with all versions of 3.* CKEditor in IE7 and IE8
Scroll down
Left click then right click in the same spot
User is randomly scrolled up either a little or to the top of the editor
Attached wmv of workflow
Has anyone else encountered this, if so has anyone been able to work around it?
Scroll down
Re: Unexpected scrolling on click, Reproduced in demo page
I happened to have changed the setting in the config.js file for the doctype
config.docType = '<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">';
Hmmm ... don't do that... i wanted to have my users pages that they create come up as transitional 4.01 so that's I set this but there seems to be some sort of conflict in doing this. If you didn't do that but you're having the jumpy issue still, try checking your config.js for a changes that may have gone astray -- ciao ...
