I'm playing around with ckeditor 3.3
Everything works fine with that sample.
But when I change line 125 from
to
I can't select that style from the combobox, although it is displayed ok (as "Ströng Emphasis").
The selection markers changes to it, but it doesn't response to the mouseclick!
It was the only modification I did!
We need names with umlauts (äöüß etc.) for our styles!
What is the right solution for that?
thanks in advance
Michael Mo
_samples/output_xhtml.html
{ name : 'Strong Emphasis', ...to
{ name : 'Ströng Emphasis', ...I can't select that style from the combobox, although it is displayed ok (as "Ströng Emphasis").
thanks in advance
Michael Mo
Re: Umlauts inside StylesSet-Combobox don't work
In the meantime, you should be able to make it work using the utf8 character (ö) instead of the HTML entity (just use an editor that saves the file correctly)
