Hi. English is not my primary language, so please be carefull.
I have CKEditor, with toolbar items that i have added. In first time, i was one instance of editor, an i used a custom toolbar. It worked.
But, the DIV when i use editor is very small and i prefer have a big one. So, my idea is to have a small, without toolbar, and a big, with it. The big editor is inserted in a jQuery UI Dialog. It work but i haven't my custom items in big editor.
So, my code :
- In the page, i have a textarea named editor1 (it's original :p)
- i instance an editor with "editeur1 = charger ('editor1',false)"
- "charger" function define for false a empty toolbar, and for true, a custom toolbar. For both, the next lines are :
Like i have found in samples. Next, i create an other editor :
- i clone the editor1's textarea.
- i create an jQuery UI dialog and i append clone of first textarea in.
- i make a charger() for editor2, with true for toolbar full.
Note that the problem is the same if i set the full toolbar for both editors. The editor1 has so a good full toolbar but the editor2 has not.
Note that if i don't start the editor1 (if i commente the function who instance it), editor2 has a good full toolbar.
Note that "pluginsLoaded" event is called only for editor1, but it changes statics property, so, i don't understand why the problem is.
AnyOne has an idea ?
So, my code :
editor.on( 'pluginsLoaded', function( ev )
// If our custom dialog has not been registered, do that now.
if ( !CKEDITOR.dialog.exists( '*****' ) )
var href = document.location.href.split( '/' );
href.pop();
href.push( 'api_dialog', '****.js' );
href = href.join( '/' );
CKEDITOR.dialog.add( '*****', href );
Re: Two instances of CKEditor but not loading plugins for se
http://alfonsoml.blogspot.com/2009/11/c ... -fast.html
function charger (name,toolBarDisplay) {
var editor = CKEDITOR.replace( name, ....); // This is toolbar definition
editor.on( 'pluginsLoaded', function( ev ) { }); // I do the CKEDITOR.dialog.add
editor.on('instanceReady', function (ev) { }); // I do editor.addCommand() and editor.ui.addButton()
Not work
I have added alert() for plugin loaded and instance ready : for the second instance, toolbar is already here befor alert() called. So, it's hard ^^
