I am using Drupal 7 + WYSIWYG + CKEDITOR, all latest version on official site
I found that when I paste the following text into CKEditor:
Global Positioning System (GPS)
It will not be able to save in drupal!!!! I can paste many other things into the editor and save without problem.
I have tried with paste from word, paste as plain text and Ctrl-V, all failed... When I click preview or save, the text will not be saved or displayed again. It will just return to the same editing page.
The original text is below:
Planned Satellite-Duo feature allows seamless fusion of location data from the United States Global Positioning System (GPS) and the Chinese BeiDou(COMPASS) Navigation Satellite System.
When I delete the term Global Positioning System (GPS) , it all works...
Re: Strange problem on Pasting (CKEditor doesn't like GPS!)
I tested this with latest DEV version and latest release version (7.x-1.2) and it works fine.
Please disable CKEditor module and try save you article in drupal. Can you do this without CKEditor ?
When you save this article do you have any errors in Firebug console (Firefox add-on) ?
What theme do you use and what other modules do you have installed/enabled ?
From which country you try add this article ?
