With the 'Image' dialog as an example, how do I assign default values to the fields (and then disable them)...?
I don't want my users to specify image size, padding, and alignment. How can I assign those fields the values I want and then disable them so the user cannot change the settings?
Re: Setting default values for dialog fields
{ type : 'text', id : 'myField', label : 'My Label', 'default' : 'My default value' }disable
