hi all, im trying to insert values from a listbox into the ckeditor
i did use the below, but after using ckeditor it failed so i used setdata and it replaces the whole textarea i just want it to add to the data not replace
anyone know how?
thanks alot
Alex
anyone know how?
var insert = form1.FieldsList.options[form1.FieldsList.selectedIndex].value; //document.form1.TextBox1.value += insert; CKEDITOR.instances.TextBox1.setData(insert);
thanks alot
Alex
Re: SetData to add to current text not replace?
CKEDITOR.instances.TextBox1.insertHtml(insert);
