I've initiated a textbox using PHP:
I have a onSubmit function set up with the form:
How do I set focus in the 'editor1' textbox, assuming the user submitted the form with no text entered?
thanks!
$initialValue = 'do not delete me!'; $fieldname = 'editor_1'; $CKEditor = new CKeditor() ; $CKEditor->basePath = '/ckeditor/' ; $CKEditor->returnOutput = true; $CKEditor->config['skin'] = 'v2'; $CKEditor->config['height'] = 200; $CKEditor->config['resize_enabled'] = false; $html_textbox = '<p>' . $CKEditor->editor($fieldname, $initialValue, $config, $events) . "<p>";
<script language='javascript'>
function CheckForm(theForm)
editor1 = trim(removeHTMLTags(theForm.$fieldname.value));
if (editor1=='')
alert('editor textbox is blank!');
return (true);
<form action=$_SERVER[PHP_SELF] method=post onSubmit=\"return CheckForm(this)\">$html_textbox<input type=submit name=submit_form value='go'></form>";How do I set focus in the 'editor1' textbox, assuming the user submitted the form with no text entered?
thanks!
Re: Quick & Simple question -- Focus()?
CKEDITOR.instances.editor_1.on('focus', function() { alert('hello world!'); return false; } alert('the form was not submitted'); return false;When this is added to my if statement, javascript returns no errors and the form is submitted. If I take out those lines, the alert box "The form was not submitted" appears and the form is not submitted. I'm using firefox and nothing is showing up in the errors or warnings to indicate what could be going on.
Thanks for any help / insight.
Example validation function:"
ValidateForm() { var oEditor = CKEDITOR.instances.my_text_box; my_text_box = oEditor.getData(); if (my_text_box=='') { alert('my_text_box must be filled in.'); oEditor.focus(); return false; } }
