I actually think we have the exact same problem. I get the move cursor too.
And you are correct! It works when i remove the style sheet. It's the height on the h1 that does it. I think it has something to do with a word 2007 component in the browser when using rich text formatting (are you using word 2007?). Because when you open a word 2003 document in 2007, it does the same kind of thing. I'll see if i can figure out a work around, and i'll post it here if i do.
Thanks!
EDIT: it's a bug in ie, and i don't see a work around...
I'm able to reproduce the problem with IE 6 and IE 8 (MS Office 2007 is installed on both systems).
Questions: - Why do you see a correlation between the problem and MS Office 2007? - What happens on a system where MS Office 2007 isn't installed (unfortunately I have none)? - Why do you think it's a bug in IE? - Did you find a (MS) defect description? If yes: Could you post the link?
Re: Problems with h1's in ie
http://cksource.com/forums/viewtopic.php?f=11&t=17420
Thanks!
Questions:
