There are too many blank lines inserted in the text when I use CKeditor.
If I have a text with just a few lines and change it two or three times the text will expand with new blanc lines for each save I do.
My installation of CKEditor is standard. It is the same situation if I run it locally or at the Webhotel (One.com). CKEditor is version 3.6.2 (revision 7275)
I have tested in IE, Firefox and Chrome, same thing.
The implementation is done in a PHP-file.
I just entered this one liner:
This is just a one line text for a start.
In my database (MySQL) it ended up like this:
<p><br>This is just a one line text for a start.</p><br>
Then I bring it up again in CKEditor just to look at it and save it again.
The result in the databse is this:
<p><br> <br /><br>This is just a one line text for a start.</p><br><br /><br>
As you see the CKEditor adds new pagebrakes all the time. Why?
With a two line text it looks like this in the CKEDitor:
This is line one. Ended with an Enter strike.
This is line two. Also ended with an Enter.
After first save it looks like this in the database:
<p><br> This is line one. Ended with an Enter strike.</p><br>
<p><br> This is line two. Also ended with an Enter.</p><br><p><br> </p><br>
And after a second save it looks like this:
<p><br> <br /><br> This is line one. Ended with an Enter strike.</p><br><br /><br><p><br> <br /><br> This is line two. Also ended with an Enter.</p><br><br /><br><p><br> <br /><br> </p><br><br /><br>
Re: Problems with CKEditor. Too many blank lines inserted.
I´m no expert in PHP, but where to look?
I realize that you are right, now that I have tested another editor software with the same result.
So now I need to find out how this happens and that is not a CKeditor problem.
So thanks so far.
Maybe the call is wrapped in a library or there's other function that does the same change, but you'll have to debug your code and find the place where the new lines are transformed in <br>
Perhaps it is worth a try, but now I have fixed it by using another product that is not giving this problem.
