Hi everyone,
First I apologize for my bad english.
I'm a new to ckeditor and ckfinder (of which i bought a license) and I dont understand one thing.
In Ckeditor, if I type a line of text, then select it and hit the "text-align:center" button, the line goes as expected, in a centered position. But then, if I press Enter some times, type some more text on a new line, select the new line alone and press the "text-align:left" button (or another alignement button), both the lines go to the new alignement position, which is not what users of text-editors liks MSOffice would normally expect... I would have expected that only the second line would be aligned to the left as if it was a new paragraph but pressing Enter or pressing an alignement button for the second time just changes the first paragraph element and does not create a new one with the new alignement position.
If I display the source, I see that pressing Enter just introduce some <br /> tags in a <p style="text-align:center;"></p> element and that the second time I press the align:left button does not close the first <p> element (the centered one) and create a second one for the second line to align it alone to the left. Instead, it changes the text-align property of the first <p> element, moving to the left the whole text...
Am I doing something wrong? How do I do to have a new paragraphe created, and align it alone to the left after a centered paragraph?
Thanks a lot,
Frederic
Thanks a lot,
Frederic
Re: Problem with text-align
Do you mean on my OS or in the CKEditor config?
On my OS, I dont think I have done anything that modified the Enter mode. Openoffice, TextEdit or my IDEs (netbean, eclipse) work just fine and I have noticed no change since I own the machine.
Regarding the CkEditor configuration, I havent changed anything except for the CKFinder config.php file. And even in that file, I havent touched anything else than the CheckAuthentication() function, license key and baseUrl/baseDir...
I instanciate a new Ckeditor according to the javascript method, but through php. I know this is not the perfect way to do it, but it works and solves most of my client's prerogatives...
$s .= ' <script type="text/javascript"> var lang_block = document.getElementById("sessionLang"); var lang = lang_block.innerHTML; lang = lang.toLowerCase(); var editor = CKEDITOR.replace( \''.$this->name.'\', { defaultLanguage : lang, language : lang, colorButton_enableMore : false, contentsLangDirection : \'ltr\', toolbar : \'Full\', disableNativeSpellChecker : false, enterMode : CKEDITOR.ENTER_BR, height : 300, resize_enabled : false, uiColor : \'#E9E9E9\' , toolbar_Full : [ [\'Maximize\',\'Preview\'],[\'Source\'], [\'Undo\',\'Redo\',\'SelectAll\'], [\'NumberedList\',\'BulletedList\',\'-\',\'Outdent\',\'Indent\'], [\'Link\',\'Unlink\'], [\'Font\',\'FontSize\'], \'/\', [\'Bold\',\'Italic\',\'Underline\',\'Strike\',\'-\',\'Subscript\',\'Superscript\'], [\'JustifyLeft\',\'JustifyCenter\',\'JustifyRight\',\'JustifyBlock\'], [\'Image\',\'Table\',\'HorizontalRule\',\'Smiley\',\'SpecialChar\'], [\'TextColor\',\'BGColor\'], ] } ); CKFinder.setupCKEditor( editor, \'/csea/plugins/ckfinder/\' ); </script>'; return $s;Shift+Enter works the same way as Enter alone.
I have tested the whole thing on a MacBook Pro with Snow Leopard on it. Could it be the reason?
