I've a problem with scayt and my application.
I'm using the last version of CKEditor, 3.4, but I've the same error with the 3.3 version.
I load a page into an iframe. In this page i use CKEditor.
I receive this javascript error when I try to enable scayt:
'scayt' is null or not an object
I use this configuration for CKEditor:
CKEDITOR.DIALOG_RESIZE_NONE = true;
CKEDITOR.editorConfig = function(config) {
config.toolbar = 'HelpDeskToolbar';
config.resize_enabled = false;
config.height = '290px';
config.enterMode = CKEDITOR.ENTER_BR;
config.language = 'it';
config.scayt_sLang = 'it_IT';
config.scayt_autoStartup = false;
config.removePlugins = 'elementspath';
config.toolbar_HelpDeskToolbar =
['Undo', 'Redo'],
['Print', 'SpellChecker', 'Scayt']
How can I resolve this issue?
Thanks in advance.
['Undo', 'Redo'],
Thanks in advance.
Re: Problem with scayt and iFrame
This problem is really reproduceable with the current version of SCAYT, but we have already fixed this issue in SCAYT core. In the nearest time we will release the new SCAYT core and will propose a patch, which switches CKEditor to the new version of SCAYT. We expect that this patch will be included in the next CKEditor's release.
