Hi all,
Sorry if this subject has been covered before, but I couldn't find an answer... So here's the problem, and I'm pretty I'm missing a stupid thing somewhere :
I got a textarea, which contains a description (long text) coming from a MySQL DataBase and place inside the textarea tag... So I end up with something like :
I'm pretty it worked well until today, which is very bizarre cause I didn't touch or change anything inside my code...
The problem is, when I load the page with the CKEditor instance, everything works fine (meaning the CKEditor loads fine) but the body of that instance is empty, and I'm not even able to write anything in it....
Actually, I should get the php $param inside the body of CKEditor, and this is only working fine when I refresh the current page.....
I tried to check on google, or to check the code, but it doesn't work....
The method I'm using for loading CKEditor is that one :
So that loads the CKEditor at first, but it seems to be locked and my text ($description) doesn't appear in it... Could somebody please help me with this one???
Thanks a lot
EDIT : Forgot to say that on IE8, it works marvelously...
<textarea><?php echo $param; ?></textarea>
<td>
<textarea name="news_edit_text" id="news_edit_text" rows="5" cols="55">
<?php echo $description; ?>
</textarea>
</td>
CKEDITOR.replace('news_edit_text', {
customConfig : 'ckeditor/custom/ckeditor_config.js',
toolbar :
['Bold','Italic','Underline'],
['JustifyLeft','JustifyCenter','JustifyRight','JustifyBlock']
Thanks a lot
