I've got a problem when using links to files (unc paths) in CKEditor.
I'm using CKEditor in a asp.net application that uses a database.
CKeditor is used as part of the aspx page to enter rich text in a record thats uploaded to the database.
When i type links in the editor like \\server\folder\..., they are created correctly and work in the page when i request it in read-mode.
But when i choose to edit the record and the html data is bound again from the database in the ckeditor, 1 backslash is removed. Each time i edit the record 1 more backslash is removed.
like this :
\\server\folder\...
\serverfolder
serverfolder
How can i disable this behaviour?
It should leave correct links unaffected.
I'm using IE 7.
Thanks!
like this :
\\server\folder\...
\serverfolder
serverfolder
I'm using IE 7.
Thanks!
Re: Problem with links and backslashes
I have tried to find answer here in forum.... nothing.
There should be some solution.
