I'm encountering a problem trying to enter a portion of php code in a text edited with CKEditor (3.2).
It is a technical article and I would like to display some code inside the text using the <pre> tag.
The problem is that if I enter something like
... as soon as I switch to the source view and go back to normal view that part disappear!
It is still present in the source, but not visible in the normal view.
I tried to add this line in the config file
config.protectedSource.push(/<\?[\s\S]*?\?>/g);
I get a different behaviour but it doesn't solve the issue.
Thanks in advance!
Gabriele
<?php echo '...'; ?>
Thanks in advance!
Gabriele
Re: Problem with "<?php ?>" code...
But in any case the php code part is removed when I save the article in the db (mysql).
I'm already using the <pre> tag.
Maybe I have to parse the string with some function before saving, but I tried several getting the same behavior or different problems.
If that's right then the problem is in your code that saves to the database. If you don't get the same code, then reset the configurations to default ones.
Now it works fine switching between the two views.
At this point I think my issue is caused by the code that saves the article into the database.
I'm using the PHP PDO library, I will check if there is something specific on this matter.
If you have any advice please let me know.
Thank you very much for your help!
