Anyone can help me? Do you know if there is a transition script, which processed data before save it or transmit it to an other script? It's probably the way i've to search.
Can you change the "IMG" directory name from "IMG" to "IMAGE" or "image"?
If there is something in CKEditor which is changing "IMG" into "img" it's because "img" is also the name of an HTML tag.
Within the context you are using "IMG" it would still be a bug for it to get automatically changed to "img" but changing the directory name (if possible and practical) would avoid the bug.
Re: Problem with capitals in source code (internet explorer)
